Upping the boost on my 8-71 blown big block
Old 11-04-2013, 01:21 PM
  #1
f35rocket
SHOW GUEST
Default Upping the boost on my 8-71 blown big block
Here's the set up. 468 BBC. 8-71 with 2 750's. Jetted square with 72's. 8 to 1 pistons. 61 top pulley, 54 bottom, for about 9% under-driven. Runs on 93 octane pump gas. Chassis dyno'd at 461 hp, 420 ftlb tq. I'd like to kick up the boost, without having to go to race gas. I figure swapping the pulleys would be way too much, even jetting up the carbs. So, what size top pulley can I go to? And how much higher on the jets?
f35rocket is offline
Old 11-05-2013, 05:42 AM
  #2
oldandtired
oldandtired's Avatar
Something is big time wrong, those dyno numbers are too low.
oldandtired is offline
Old 11-05-2013, 06:04 AM
  #3
f35rocket
SHOW GUEST
I thought so too. It was on a portable chassis dyno at a car show, so who knows how accurate?
Old 11-05-2013, 01:37 PM
  #4
zipper06
Do you have a boost gage? Is the blower teflon stripped?
You can probably get away with 1 to 1 ratio with 93 octane but i wouldn't think any more than that.
zipper06 is offline
Old 11-05-2013, 03:10 PM
  #5
f35rocket
SHOW GUEST
Thanks for the response!
Old 11-18-2013, 05:47 AM
  #6
f35rocket
SHOW GUEST
Is there any "rule of thumb" as far as jetting increase, when changing pulleys from 54-61 (9% under) to 54-54 (1 to 1)? Like, maybe, one jet size per two teeth or something? Just some sort of starting point, so I don't melt pistons trying to find the right combo!
Old 11-30-2013, 06:56 AM
  #7
roadkill2
Default Re: Upping the boost on my 8-71 blown big block
Never heard of a "Formula" like that . . It's just "More air . . More Fuel".
Start with jetting that should put you rich and then lean it out to taste . . Kinda like making Chile . . .
roadkill2 is offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
