Thumper Cams
#1
Member
JUNIOR BUILDER
Anyone ever used a Thumper Cam? Do they really sound like a much bigger cam yet remain street friendly? I was thinking about installing one in my 39 Olds Street rod with a Stock 350 Chevy. Any feed back is appreciated.
#5
Member
MASTER JOURNEYMAN
Stay away from any thumpr I used mine for only 1400 miles swiped 6 lobes flat.
Donn't gofor sound go for the power and torque forget about the idle its a bonus. Sent the cam back to comp and told them to take it back to China.
Not only myself 6 customers can vouch for that. What are your goals and the specs on your motor how radical do you want to go and what rpm range and stall?
#6
I've never used one. I only know one guy that did. It did sound absolutely awesome. And he said power was up from his stock cam. He was afraid of bottom end power loss and he claimed there was no problems. Just my two cents.
#7
Member
JUNIOR BUILDER
#8
Greyhound gears and a smooth engine if you're going to drive the damned thing farther than your local Sonic . . at freeway speeds . .
As for the "Fake Blower", just more crap hanging off the accessory drive you'll need to fix somewhere 100 miles from where you want to be . .
IF . . You're gonna cruise or drive a street rod very far frequently, keep it as simple as your talent and ability to make it work. Hot Rods and Street Rods are two different things . . .
#9
just put a lunati cam in it and you will be happy. i had a 82 camaro z28 with a 355ci motor/stock bottom/ lunati cam with stock alum heads off an 85 corvette and a rock crusher tranny and 411 gears.... that car would stay side ways more then it was straight and it had great sound going down the road at low speed and sound mean on the gas hard
#10
Member
MASTER JOURNEYMAN
Do you have aftermarket valve springs or stock springs? Do you have screw in studs or roll pins or neither? I've got a couple of good gringds that will make you happy but it depends on your valvetrain. I agree very much with the other poster Lunati makes great products.
