engine
Old 02-27-2012, 07:24 PM
  #1
milkcr8
SHOW GUEST
Default engine
can i bore a 1960 283 to 4 inch bore safely
milkcr8 is offline
Old 02-28-2012, 08:56 AM
  #2
TS1955
DYNO OPERATOR
Best way to find out is have it sonic tested.
TS1955
TS1955 is offline
Old 02-28-2012, 09:47 AM
  #3
oldandtired
oldandtired's Avatar
TS1955
x2. Back in the day, we would bore +.060 to make a 292 screamer.
oldandtired is offline
Old 02-28-2012, 06:11 PM
  #4
markdunlap
DYNO OPERATOR
Default engine
I think it would be easier to just start with a 350 block.
markdunlap is offline
Old 02-28-2012, 08:05 PM
  #5
zipper06
I did bore one to 4.00 in the early 60's making a 301" and got away with it, it ran damn good in my 55Chevy 4 dr. but i'm not suggesting that every blk will bore to 4.00.
zipper06 is offline
Old 02-29-2012, 03:01 AM
  #6
hink
EXPERT BUILDER
Default Re: engine
Sonic test first as I have seen some that will and some that will not!!!
hink is offline
Old 02-29-2012, 02:05 PM
  #7
olds48
Unless you have a high dollar set of pistons that you absolutely MUST use on this build, I wouldn't even worry about it. The HP gain from a handful of inches is no where worth the headache you could create for yourself. Just cram a bunch of compression in the motor and a some GOOD parts in the valvetrain and let her rip. I love hearing those old small cubic inch motors screaming at 8000+ rpm. Ya gotta love it. It makes me reminisce about times that were before my time :?
olds48 is offline
Old 03-09-2012, 07:23 PM
  #8
burgessdg
JOURNEYMAN
Default Bore 283
Let me summarize. Can you bore a 283 to 4"? Yes. Have guys done it without sonic testing the block? Yes. Were they lucky? Most were. The purpose of sonic testing is because during machining operations on a new block, there is room for error. You want to call that core shift? Bottom line is if the machined bore is not in the center of the cylinder casting, there most likely will not be enough meat on the short side to allow the motor to survive. So you put the dough in it and then waste all those parts... My solution to that dilemma was to find an old 327 with a small journals, and put the 283 crank in it. Good luck.
burgessdg is offline
Old 03-10-2012, 04:53 AM
  #9
hink
EXPERT BUILDER
Hell just find a 350 block put the Clevite MS 1110 H bearings you can use a small journal crank in a large journal block!!!
hink is offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
