Longest stroke in a Merlin block
Old 10-10-2011, 02:44 PM
  #1
rrrdad
APPRENTICE
Default Longest stroke in a Merlin block
Just like it says. What is the longest stroke you can put in a merlin standard and tall deck?
rrrdad is offline
Old 10-11-2011, 02:22 PM
  #2
Tod74
4.375 in the 9.8 deck 4.75 in the 10.2" deck
http://www.worldcastings.com/product...vrolet-blocks/
Tod74 is offline
Old 10-11-2011, 04:36 PM
  #3
rrrdad
APPRENTICE
ok great... can a 632 be a wet sump?
rrrdad is offline
Old 10-15-2011, 01:11 AM
  #4
michael1
You can actually put a 4.50 in a 9.8 deck but I wouldn't do it, Scott Shafiroff builds a 598 in a 9.8 deck block. Are you going with a block that has a raised cam?
michael1 is offline
Old 10-15-2011, 05:03 AM
  #5
hammertime
Actually you an put a 4.625 in a 9.8 and make a 615 APD does it all the time
hammertime is offline
Old 10-17-2011, 09:42 AM
  #6
michael1
That's why I asked about a raised cam block, BES does stuff like that also. APD does alot of testing on all kind of stuff, they had a real good article a couple of years ago on some Big Chief testing that they did. I don't think APD gets as much credit as they should.
michael1 is offline
Old 10-18-2011, 08:26 AM
  #7
hammertime
Actually do not need a raised cam block. Mine is a 4.5 stroke in a 9.8 deck also.
That article was the start of a major change in cam profiles, the engine was a good friend of mine, he purchased from a big name builder and put a terminator on it. It developed the mystery "alky miss" and did not run nearly as well as it should of. APD was close so John Kyle did a bunch of work and figured it out with a cam he designed. They also have designed some of the best bbc heads on the market.
Old 10-19-2011, 08:20 AM
  #8
maxpower671
SENIOR BUILDER
like to hear more about this 'alky miss'....is this the miss big inch alky engines develop...and a longer exhaust duration helps clean it up?? :?:
maxpower671 is offline
Old 10-19-2011, 06:59 PM
  #9
hammertime
There used to be a article on APD's website but they recently updated it and I can not find it. Maybe search the net for it. Should be APD and Big Duke Head. Exhaust duration is part of it.
Old 10-21-2011, 12:21 AM
  #10
michael1
That article is the reason that my cam has the specs that is has. APD did alot of testing with the 18* stuff.
michael1 is offline
