Has anyone ever heard of running 26* of timing at idle?
#1
DYNO TECH
I have been having a stumble issue on my small block Chevy when I stab the throttle wide open. It happens from idle, happens from 1st gear and happens from cruising under 4000 rpms. If I ease into full throttle its fine and the car rips, but if I stab it fast the car falls on its face then takes off.
I have a guy giving me advice that my initial timing needs to be 26* at idle and curved to run 36 by 3000...I have always ran 12*-16* on this motor and have it set at 12 initial right now and all in 36 by 3000, all I changed was the Carburator from an 850-to a more streetable 750 double pumper. Im thinking my pump shot nozzles are just too smal and the carb needs to be jetted properly, but one guy keeps giving me this timing advice and Im skeptical to follow it.
Here is the break down of the engine itself:
355 SBC
10.3:1 compression
64cc heads
Lunati 550 lift 288 degree cam
Weiland 17530 manifold
Holley 750 CFM double pumper
456 gear
powerglide
Car weighs 2800lbs
28" tire
355 SBC
10.3:1 compression
64cc heads
456 gear
powerglide
Car weighs 2800lbs
28" tire
#3
DYNO TECH
Originally Posted by itsabird
It's not unheard of, consider guy's running locked out timing, before i went there, i would try larger squirters in the carb.
#9
50cc pumps supply enough fuel to feed a methanol or E85 Dominator. Why do you think any 4150 would need that much fuel for gas? Make the engine burn the fuel correctly and you don't need to add that much fuel. Sufficient timing, the correct heat range spark plug, the right fuel for the compression ratio, a quality ignition system... all these things make the engine you have burn the fuel best. We can add that more compression helps, better cam, better cylinder heads, but that adds a bit more money. Do the things you can to make the engine work better at burning the fuel.
It's hard to say without knowing your .050 cam info, if 288 is advertised then probably around 230. Converter should probably be a 10" and stall will need to be around 4000 RPM . And most likely it will also need to have the timing locked to perform best. What plugs are you running and what heads?
#10
DYNO OPERATOR
Before you do anything to the shooters, you more likely have slack in the accelerator pump linkage or a way too weak spring, but more likely slack in the linkage. While shut off and at minimum idle, barley move the throttle blades and see if you have a pump shot with the least movement of the throttle blades. It you don't you need to adjust the spring tension at the pump lever to take up that slack. Then after making sure this is responsive you can begin changing shooters and cams in that system.
Float level being low can also cause low speed stumbles.......
Bruce
Bruce
