Oversize SBC rod bearings
Old 06-07-2011, 01:28 PM
  #1
oldandtired
oldandtired's Avatar
Default Oversize SBC rod bearings
I have new BBC stroker crank (odd length) with SBC rod journals. My problem is I have way too much clearance and the only oversize I find is .001.
Does anyone make a .002 or more? (I'm measuring 2.0972 on the crank).
I just hate to turn a brand new crank to .010.
Thanks, Dave
oldandtired is offline
Old 06-07-2011, 05:49 PM
  #2
fla1976
fla1976's Avatar
Hope this helps. It lists large journal sbc rods and main sets at +0.002" sizes.
Paul.
http://www.competitionproducts.com/C.../products/737/
http://www.competitionproducts.com/C...products/1403/
fla1976 is offline
Old 06-08-2011, 09:47 AM
  #3
oldandtired
Thanks FLA. I have their catalog but did not think about going on line. Dave
Old 06-08-2011, 09:58 PM
  #4
zipper06
Hey Dave i think you mean undersize bearings, almost everone sells them. The oversize bearing comes with an HX.001/HX.002. i think if you get a .001 undersize bearing it will not be too much clearance for a B/BLK stroker, i try to put .0025/.003 min clearance on every B/BLK i build and run 20/50 oil.
zipper06 is offline
Old 06-13-2011, 10:34 AM
  #5
oldandtired
Thanks Zip.
I was confused on the sizes and they way they describe them. Apparently race bearings are only available in .001 and 1X.
I ended up buying the CB663P002 which is the Clevite 77 standard bearing and milling the chamfer in them. I am to .00250 to .00275 oil clearance now.
Dave
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
