1/4 MILE STEERING PROBLEM
#1
SHOW GUEST
67 camaro, 1/4 mile run, running 11.4, 119 mph. I have to steer the car to correct for constant fishtailing through the entire 1/4 mile. Now I know the tires are not spinning all the way through. Running 10 inch street slicks, GM 12 bolt 3.73 posi gears on standard 67 Camaro suspension with traction bars. I have the welded in subframe connectors. What are the various possibilities to check and in what order?
#3
SHOW GUEST
M&T ET STREET SLICKS, started with 15lbs, ended with 12lbs, didnt seem to make a difference. I am wondering if it may be related to the caster adjustment. I had a roadster, put 18" wheels on it and it was all over the place on the road.Readjusted the caster, problem solved. What do you think?
