BBC lifters
#2
I'm running the Isky EZX lifters .904 lifter bore. These don't have the needle bearings. I've run them two seasons so far probably a little over 100 passes with no problems.
I know there will be others that will say they are too expensive but when I was building my engine most others were having problems at less than 50 passes.
#3
#4
#5
Curtis
#6
#7
Mine are CRANE Ultra Pro. probably made by morel or someone else iduno. they were like $514. Hammertime had a place to get good lifters cheap but forget where it was.
stay away from comp. heard too many horror stories. I also had one come apart early but might have been due to me setting lash too loose.
#8
Hammertime runs Morrel lifters I believe.
#9
EXPERT BUILDER
We lean towards the .904 lifters in most of our appications and with the bigger body, axel and bigger wheel is a win win situation.
When running the bigger wheel you should let your cam grinder know as most .904 rollers have a .810 wheel compared to a .750 wheel on the .842 lifters.
#10
