BBC Shaft rockers
#1
SENIOR BUILDER
need some info on the T&D rockers. Do they need any machining to install (afr heads) Do they have aligning brackets like the Jesel ? I cant seem to find any good lit. on the T&D. AFR says the T&D fit their heads better. any input on the subject here ? I dont really want to get into any machining unless I need to. Bolt on would be great .lol
#3
DYNO OPERATOR
Originally Posted by blowninjected540
Just mounted a set of T&D on my dart 380 heads nice bolt on no problems what so ever. Very happy ordered mine thru brodix they gave me the best deal.
TS1955
#5
SENIOR BUILDER
I talked to an engine builder here about the T&D shaft rockers, and he showed me a set mounted on a BBC, they have to be pinned to the heads or they may spin, then you`ve got problems. lol. so how do you guys get away without pinning, do they have a set that does not need pinning. ?
#6
DYNO OPERATOR
TS1955
#8
My T&D's are not pinned either nor were my crane shaft rockers on my 23* heads. They did have a cross link between them. I do not recomend the Crans ones because we had to add looooootttts of shims to make 'em work.
#9
TS1955
#10
The T&D sportsman shaft rockers do have to be pinned as they are individual stands.The sportsman's do not have the one piece bar.I run the T&D sportsman's on a BBC. These rockers don't have pressurized oiling to the bearings,they rely on oil splash.I have run these since 2008 and have not had any problems.
