Dropped a valve
#1
Dropped a valve on my fresh built 540.The exh. valve on #2 cyl. broke about 3/4 of a inch down the stem.?Wtf.Ferrea 6000 series valves,4.5 bore with 4.250 stroke,rhs heads,lun cam 740 exh 758 int lift.Put a new radiator in the car and was in the shop checking the car fired it up and ran it for 8-10 minutes only got to 150,so got out of the car and started checking for leaks,bliped the gas by hand a couple of times to help put a little more heat in it,sounded funny so jumped back in the car to check oil psi it was 55,hit the gas one more time(dumb ass)to clear it up when it came back to idle,it locked up.!!
Never seen one break at the stem like that,zero passes on the motor,only shop time may be an hour and half of run time.one pass down the local road in front of the house,it saw 6000 rpm on that pass,but lots of run time after that.Roller cam and howards roller rockers crower roller lifters all brand new.pulled the heads and the others 7 cylinders are happy,No contacts marks on any other valves or the pistons.WTF??
#2
I know this isn't helpful and you are looking for a cause, but I will still say it anyway.
Dude...that f*&*ng sucks.
Your luck is about as good as mine. Did it just break or did it break because it dropped and got smashed? How much damage to the block and head?
#3
If it wasn't for bad luck,wouldn't have any luck.!!!!!,Don't think i can save the head(brand new) piston has several holes in it,(brand new) and yes it looks like the stem broke and then the valve dropped.never seen one break at the stem like that before.As i said before the other seven cylinders are happy,and look great.Beats me?The valve spring came off with the stem still in place with the keepers ,and retainer all in one piece.!!! go figure.
ops:
ops:
#5
1st Thing I would check?
Coil Bind on the Rest of the Valves?They DONT jsu Break,for NO Reason?
Who set the Heads Up?
I would'nt see why the Head cant be Saved?
I have had them come apart at 9000 in the Lights and,a little Dye Grinder Action,Some Alu.Tig work,a few New Seats and Valves.And back at it!
If it broke at a Idle,IT CANT BE TO BADDD!
Later
G 8)
Later
G 8)
#6
DYNO OPERATOR
TS1955
#8
It's possible the rocker geometry is off. If the roller was rolling too close too or off the edge of the valve the side load could have broke the stem in the area you're describing.
#9
I will check this very close when i put it back together.
#10
DYNO OPERATOR
TS1955
