G body front tubular a arms
Old 11-14-2010, 08:04 AM
  #1
markdunlap
DYNO OPERATOR
Default G body front tubular a arms
Thinking about tubular A arms for a 1980 BBC MAULIBU. I found some on maliburacing.com and gbodyparts.com . They are BMR brand at $560 and are made with DOM tubing. Anyone using these or suggest others? The CM ones are $900 which is not in the budget.
This is for bracket drag racing. My stock A arms are OK, but going to be rebuilding them if don't go to the tubular ones.
I also found some plastic front inner fender panels for $250. anyone else know of others?
markdunlap is offline
Old 11-14-2010, 10:33 AM
  #2
zipper06
Mark,
Can't you find an old malibu or elky around, they are the same from 1978 to 1988 and they are plastic from the factory, i still have the originals in both my 80 Malibu and my 79 Elky. I only cut a small section out of the left front for the front mounted fuel cell.
I think the Olds and Buicks G bodys have the same panels in them.
zipper06 is offline
Old 11-14-2010, 11:02 AM
  #3
mytmouz
mytmouz's Avatar
http://www.speedwaymotors.com/Chrome...-Arm,5584.html
Use 2 right side arms...
mytmouz is offline
Old 11-14-2010, 11:59 AM
  #4
markdunlap
DYNO OPERATOR
Default G body
I already have plastic ones but they have seen better days. Looking for new ones just for cosmetic reasons.
If the Speedway chrome moly upper A arms 91031134 fit a Malibu, then they are what I am looking for. They also have Moog ball joints for $15 each. Couldn't find any lower tubular ones though in Speedway. Maybe stock car guys don't use them?
They are symetrical so you can use 2 right hand ones? I see the left hand one listed is 1/2" wider for a stock car.
Old 11-14-2010, 12:16 PM
  #5
Tod74
Originally Posted by mytmouz
http://www.speedwaymotors.com/Chrome-Moly-Upper-Control-Arm,5584.html
why? just curious
Tod74 is offline
Old 11-14-2010, 12:50 PM
  #6
mytmouz
mytmouz's Avatar
Roundy round stuff has one side longer for the stagger to be built in, the right side is stock, so you use 2 rights, just flip the center link over, if it not universal...Tubular lowers are hard to come by. TRZ makes some for a s10, which is the same, but they are pricey...
mytmouz is offline
Old 11-14-2010, 02:49 PM
  #7
Tod74
thanks for the explanation
Tod74 is offline
Old 11-16-2010, 02:39 AM
  #8
JEFF69Z28
DYNO OPERATOR
TRZ MOTORSPORTS IN FLA.LOOK THEM UP ON THE NET.
JEFF69Z28 is offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
