stuck on rear section of car.......
#1
APPRENTICE
I was thinking to weld OEM quarters on my 70 bird but almost had a heart attack when I seen OEM 1/4's for a 70-73 bird runs for 1500 a side on average just to buy. Checked out reproduction 1/4's and the metal is somewhat less then standard and though extremely cheaper in price, only go up to the body line where the OEM's go Jam to Jam. I refuse to put filler across my 1/4's (especially on it's lines) if I am hanging up new 1/4's as this makes no sense and defeats the purpose. So I am thinking a donor shell from a salvage yard that specializes in my car. My question is I know there is extra work involved, not to mention getting rid of what's left over on the donor shell but if anyone has any experience with this, would this be a more feasible route? I know one plus is the metal gauge will be the same and I know a yard that has decent to very clean shells but in the end will I regret it? Just trying to decide if I should bite the bullet and buy the 1/4's or go the donor route.... for the record the cars is solid but for some reason on these F-bodies the trunk jambs are always screwed as with this car and the same with the r/s 1/4 itself. Below are two pictures of the trunk jambs to show what I am up against.
Thanks in advance, Lujo
#2
MAN, there are so MANY used up NON rusted F'birds out here in the West !
If you could obtain just a titled shell you'd be eons ahead of that mess ya got there. Out here it'd have to be a really RARE piece to put the kinda work in it as you need to do on yours.
#3
If you can get oem's by all means buy them!! stay away from the repops . I haven't come across any of the that didn't suck the^$#&*#@ !! my next choice would be the donor car, but your in for a lot of work.
#4
APPRENTICE
ops: lol
#5
APPRENTICE
I was just hoping I would save big with the donor considering all the sheet metal being there to use for other spots. But I see your point....
Hey thanks again, I appreciate the input. Sometimes it gets hard to think with a clear head without an experienced opinion.
~Lujo
#6
If it is a rare car you could commit a felony and re body the car by putting the tags on another shell( Big NO NO ) I am certain it happens a lot with chevelles.....not saying it is ok just saying it happens...OR you could clip it at the windshield posts and DOOR JAMS and retain the factory cowl and numbers.....so technically it is the same rare car even though it isn't....but if it isn't anything special compared to the donor car I wouldn't bother.
example LS-6 chevelle vs a plain Jane Malibu.
jmo
I never have been fortunate enough to hang new OEM Quarters,so I don't have any experience to compare to, but I've used re pops on a couple cars that fit well. jmo
jmo
#7
APPRENTICE
jmo
jmo
You are correct also btw on those Chevelles out there, but Chevelles aren't the only cars to suffer that fate. Are you a bodyman by any chance? I noticed your dead on and know the deal with what's going on out there.
Anyway as for doing a complete clip, that's not a bad idea either but due to the work involved and my limited space, I will keep that idea as a last resort.
See as I think MEMRACING62 will agree, with the repops, they are better with some cars then others. I am not sure if it has something to do with car popularity and how many they make to sell that dictates the metal stamping, but on Firebirds and Camaros, the repops just suck and only cover the 1/4 from lip to lip (not full jamb)and from lower lip on 1/4 bottom to the body line just slightly above the center, leaving a new 1/4 that has plastic across it. You and MEM might even think I am nuts but I swear those f-body repops are more shallow as well with the contour curve of the body. I think I am just going to bite the bullet and go OEM on the 1/4's. I should just call Bill's Birds and see what he can do for me.
Thanks Tod, I will keep you all updated.
~Lujo
#8
I'm not a body man....once upon a time I was gonna be. I've been fixing and painting cars since I was a teenager.My dad taught me. I just work on my own and on occasion someone will talk me into doing theirs as well.
#9
What I have done to many cars is I have gotten like a roof off of some station wagon from the wrecking yard and just cut out to rust rot and welded in "new" pieces the size that I cut out. Looking from the pics it doesnt look to bad at the seam so you might be able to salvage that part of it. Hope this helps
