street stock running hot?
Old 08-25-2010, 05:27 PM
  #1
MCdirt1
APPRENTICE
Default street stock running hot?
I have a dirt car with a .060" over 350, 450 cam, after about ten minutes the temp is pushing 200 deg. new motor,new tripple pass radiator, custom fan box, 30% reduction pulleies. Timming 4 deg. advanced Can anyone help me cool this thing down?
MCdirt1 is offline
Old 08-25-2010, 06:50 PM
  #2
mopar1968
mopar1968's Avatar
Are you running a restrictor in thermostat housing?
mopar1968 is offline
Old 08-26-2010, 03:06 AM
  #3
hink
EXPERT BUILDER
Default Re: street stock running hot?
4 degrees advanced that must be numb and should runn cool with no timing.
hink is offline
Old 08-26-2010, 09:19 AM
  #4
MCdirt1
APPRENTICE
Default running hot
I have the restrciter in at the thermo. housing.
MCdirt1 is offline
Old 08-26-2010, 09:25 AM
  #5
MCdirt1
APPRENTICE
I tried to retard with the distr. but that didn't help any, maybe go back in and set the timing to dead zero? This motor runs great, awesome power just runs too hot.
MCdirt1 is offline
Old 08-26-2010, 12:52 PM
  #6
blowninjected540
EXPERT BUILDER
I seen this before. Ended up being the wrong head gaskets.
blowninjected540 is offline
Old 08-26-2010, 01:06 PM
  #7
kwkracing
you seem to have another issue here with incorrect timing or you dont know what u are setting it at. A performance sbc will not run at zero or 4 degrees base timing. Do your headers glow orange when you run the car at night?
kwkracing is offline
Old 08-26-2010, 07:05 PM
  #8
MCdirt1
APPRENTICE
No they don't glow, the cam I have (Erson 453 lift) was matched to the build of the engine by a local speed shop and Erson said to set the timing 4 degrees +. I have a timing tab that gives a 4 degrees advanced tab, at 1000 rpm I show dead 4+ with a timing light. Am I missing something with this?
MCdirt1 is offline
Old 08-26-2010, 07:24 PM
  #9
MCdirt1
APPRENTICE
I made sure to check the gaskets during the build, I have been through that before as well, also with intake gaskets. I have even went as far as to run 40 below water treatment (two bottles) no sign of change. I am thinking possible flow issue, Heads were rebuilt by a performance shop.
MCdirt1 is offline
Old 08-26-2010, 07:31 PM
  #10
Tod74
what is your total advance? Did you varify TDC on your pointer (with a degree wheel)when you put it together? I bet that thing gets in it's own way coming out of the corner...
Tod74 is offline
