Hard Blok
#1
Member
CRAFTSMAN
To all race engine builders,had a crack in a bowtie blok so i was asked if i would like to hard blok to cure problem,sure i said but come to find out the blok was only filled on one side,is this norm or should i be worrying.lunati crank,oliver rods ,cp pistons etc. :?: :?:
#2
Member
JUNIOR BUILDER
#4
I can't imagine any one filling only one side. That would be like running two 4 cylinder engines. Although slight, the different heat would make a difference in the tune and probably the harmonics as well.
#5
Member
CRAFTSMAN
These were my thoughts also and when this is the first engine that i EVER had built for me, I have always built my own engines as that is my trade ,but you always think sometimes it could be built better and secondly this was the most i have invested ever in a sbc .Should i pull it back done and finish job or run it as he says its ok. :roll: :roll: :roll:
