Distributor sets at angle???
#1
SHOW GUEST
I have a 72 LT-1 350 I recently bought that was a total rebuild. Has not been fired yet, and had no distributor. When I got one and dropped it in the distr. sets at an angle (at the distributor seat)in relation to the manifold. I`ve never seen this before. Its almost like the distr. hole in the manifold is towards the center to much??? Its a hurricane style single plane intake. I did see somes pics on the net of intakes with an angled seat for the distr. Whats the deal here, has anybody run into this problem?? Help!!
#5
SHOW GUEST
Where the distributor sets on the manifold there is a good 1/8" gap on the outer side while the other side is resting on the manifold, very noticeable! I know oil would really run out of there. I read on one of these forums someone had the same issue and he took to a machine shop, they made him a tappered shim and I guess he ran it that way.....does`nt sound right to me?
#6
If there is a gap then your intake isn't right but the distributor in a Chevy v8 will be at an angle.It's how they are.
I assume it is because the cam is in the center of the engine and the distributor has to be to one side for the gears to mesh. :?:
#7
The dist.angle is to get the oil pump drive outside the rear main bearing bore.Nova79 I think you could have that intake machined to match one that's right.Be sure to check gear alinment and oil pump drive free play.Bill.
