jetting carb
Old 06-10-2010, 02:16 PM
  #1
greenone60
JOURNEYMAN
Default jetting carb
i have a jetting ? when the weather gets hot do you go up(rich) on the jet sizes or do you go down(lean) and ideas. 1/8 mile drag car with sbc running 114 sunnco race fuel.single carb 850 holley hp
greenone60 is offline
Old 06-10-2010, 04:08 PM
  #2
wrightway
SENIOR BUILDER
Down
wrightway is offline
Old 06-10-2010, 04:20 PM
  #3
curtisreed
curtisreed's Avatar
Originally Posted by wrightway
Down
X2
curtisreed is offline
Old 06-12-2010, 10:19 AM
  #4
chevyart
Default hot weather
what do you guys do with the timing in the real hot weather. up, down, or leave it as is ? thanks chevy art
chevyart is offline
Old 06-22-2010, 05:44 AM
  #5
chevyfireball
When the weather gets hot or the altitude goes up, the air gets worse so you can't burn as much fuel so you need smaller jets. I usually only alter the jetting two sizes.
I only alter the timing when the car is over powering the track (retard it 1 - 1 1/2 degrees. If I'm wanting to set her on kill I advance it 1 - 2 degrees. Just make sure you're checking your plug condition after each run to avoid detonation etc.
chevyfireball is offline
Old 06-22-2010, 09:21 AM
  #6
JEFF69Z28
DYNO OPERATOR
over powering the track= spining the tires?
JEFF69Z28 is offline
Old 07-02-2010, 04:30 AM
  #7
chevyfireball
Yep. Some tracks aren't prepped that well. With a glide, convertor and nitrous motor there aren't too many options to get traction without losing too much power.
Old 07-02-2010, 12:26 PM
  #8
Tod74
I never mess with mine. I leave it the same all the time.
Of course I also lose in the first round most of the time too. :lol:
Tod74 is offline
Old 07-05-2010, 10:24 PM
  #9
cepx111
I agree, hot/humid weather likes a leaner A/F ratio.
Jetting it down will aslo make it more consistent if you race where theres a temp drop from TT's to elims , E.G> daytime TT & nighttime racing.
I jet for consistency - not power/ET.\
Cp
cepx111 is offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
