Holley Black/Location??
Old 04-08-2010, 10:48 AM
  #1
Scooterz
Default Holley Black/Location??
Installing new fuel system. Having gravity & space are a concern. Have a sumped tank. Mufflers are near mounting area of where the pump should be to have gravity & space @ same time. Will heat be an issue??? I read in another thread that it could shut down the pump if it gets hot. I am replacing a high volume manual Holley pump.
Scooterz is offline
Old 04-08-2010, 11:26 AM
  #2
FullTimeRacing
DYNO OPERATOR
your manual pump is gravity fed,so anywhere on that level.
if heat is a concern make a shield.
FullTimeRacing is offline
Old 04-08-2010, 12:21 PM
  #3
Scooterz
OK. I went to the fab shop @ my work & grabbed some 1/8" steel plate to make a shield with.... I figured it would deflect heat better than aluminum. I see many reasons why people use fuel cells... with my sumped tank, I am limited for space & gravity. Thanks!
Scooterz is offline
Old 04-08-2010, 05:57 PM
  #4
cam67152
Alluminum would be a better choice, the steel will hold the heat in, if you heated two pieces of metal one steel one alluminun you could touch the alluminum way sooner!
cam67152
cam67152 is offline
Old 04-08-2010, 06:01 PM
  #5
TheYellaBrick
TheYellaBrick's Avatar
DITTO
TheYellaBrick is offline
Old 04-09-2010, 11:01 AM
  #6
Scooterz
I wondered that.... I think I had it backwards (steel VS aluminum). The closest heat source is the turn down from the muffler (the pump is slightly to the side & above it by 3 to 4". thanks Bretheren.
Scooterz is offline
Old 04-09-2010, 11:48 AM
  #7
FullTimeRacing
DYNO OPERATOR
I just thought you was being a smart a$$.LoL :lol:
Old 04-09-2010, 10:40 PM
  #8
Tod74
My chevelle has a sumped tank, I mounted my pump to the rear of the tank to the right of the car and the filter is between the pump and the tank.I made a large swoop with the hose to keep the bend "not so sharp". The pump is a bit higher up than the sump outlet but when the car launches it squats...never had an issue but it was just a small block flat tappet cam nothing special.
Tod74 is offline
Old 04-10-2010, 03:38 AM
  #9
JEFF69Z28
DYNO OPERATOR
cam67152
X2
JEFF69Z28 is offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
