454 head choice
Old 03-09-2010, 04:44 PM
  #1
gullion454
Member
MASTER JOURNEYMAN
Default 454 head choice
i have 454 that i am rebuilding for a 72 chevelle that will be set up mostly for the street but will see the strip some. i am in the planning stages right now and while shopping for parts i came across a set of gm performance heads, part number 12363390. i was wondering if these are a good set for my project. i am planning on boring it at least .30 over maybe .60 and a compression ratio about 10.5. i am not for sure about a cam yet but due to my budget it will probably not be a roller. any suggestions here would be welcome also. i am shoting for 500+ hp. the car currently has a th400 with a 3000 stall. ford nine with two sets of gears 1) 5.00 with a spool (for the strip) 2) 3.50 posi (for the street) thanks for the help.
gullion454 is offline
Old 03-09-2010, 06:36 PM
  #2
Tod74
dON'T KNOW THAT HEAD NUMBER BUT 049 OR 781 OVAL PORTS ARE CHEAP AND WORK VERY WELL IN A HEAVY STREET CAR.LOTS OF TORQUE.Sorry about cap locks too lazy to fix.
Tod74 is offline
Old 03-09-2010, 06:43 PM
  #3
cam67152
X2...... I have a set of lightly ported 049 on a 396 work very well for street strip.
If you have some extra cash the brodix oval port race rites :wink:
cam67152 is offline
Old 03-10-2010, 09:23 AM
  #4
oldandtired
oldandtired's Avatar
The 12363390 is an aluminim oval port "Bow Tie Performance" series. 2.25/1.88 valves with 11/32 stem.
Dual springs, 1.514 od, 140# at 1.94, 1.20 solid height, and 368 lbs per inch (same spring used an all 502ZZ engines).
290 intake runner
110 exhaust runner
110 semi open chamber combustion chamber
Great mid range performance.
Dave
P.S. Lose the 5.00 gear, it's too much.
oldandtired is offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
