leaving valve seals off???
Old 02-21-2010, 10:19 AM
  #1
ejm
SENIOR BUILDER
Default leaving valve seals off???
for a strictly off the street motor will it hurt to leave the seals off the valves? i know it might smoke a little but any other problems?
ejm is offline
Old 02-21-2010, 02:22 PM
  #2
TS1955
DYNO OPERATOR
I usually run them on the intake side only. JMO
TS1955
TS1955 is offline
Old 02-21-2010, 03:54 PM
  #3
wmeabates
If your going to be using a crankcase vacuum pump it will dirty up the oil quicker with no exhaust seals and a lot of vacuum.Bill.
wmeabates is offline
Old 02-21-2010, 07:15 PM
  #4
Tod74
Why do people leave them off the ex? My Brodix heads came brand new with no seals on the exhaust valves. Just curious what is the advantage in doing this.
Tod74 is offline
Old 02-21-2010, 07:37 PM
  #5
zipper06
I don't run seals, if you remember chevy never put seals on their gides, just an O ring under the keepers and this on a street engine. The guides needed a little oil to keep them from wearing, and most did after a 100,000 miles, IE the little bit of blue smoke on cold startup on and old engines. Ford ran a little mushroom bonnet type seal, which is what i use on uncut heads. With the advent of bronze guides and alum heads they came with seals, because the guide were an oil impragnated bronze, but on strickly racing engines we cut back on the oil to the top of the engines, with roller lifters and rockers, and usually only a mist of oil on top, that why i don't use them. But as mentioned in an above post, if you are running a vacuum pump, they are probably a necessary idea. I've only ran an evac/header system, no experience with vacuum pumps.
zipper06 is offline
Old 02-22-2010, 12:39 PM
  #6
ejm
SENIOR BUILDER
so f i run evac tubes to the headers like i have been then it will be alright to leave off? it goes 300 feet and the oil is changed every pull anyways
thanks
eric
ejm is offline
Old 02-22-2010, 02:15 PM
  #7
kwkracing
Leave them off and dont worry about them.
kwkracing is offline
Old 02-25-2010, 08:36 AM
  #8
chpseat987
Member
CRAFTSMAN
I have talked with several old timers on this subject, and last season Mike strausberg was at our track, his mechanic builds my friends Engines and I asked them this question. They build all race motors, NITRO, or race fuel withOUT EX valve stem seals. They said " The Ex valves do alot of work and take alot of heat, so not running the seals gives a little extra room for oil on the stems for lubrication and cooling, they can get more life out of them this way. I ran seals on them last year but when I re built my heads for this season I did not install them. I hope this helps and makes since.
I also questioned my machinist and he also agreed as long as its not a street motor dont run the seals on the Ex valves.
chpseat987 is offline
Old 02-26-2010, 11:26 AM
  #9
ejm
SENIOR BUILDER
so when i put my heads back together should i get some for the intake or let them ride too?
ejm is offline
Old 02-28-2010, 12:20 PM
  #10
obsessedtruck
Member
JUNIOR BUILDER
Id leavem off.. Especially with a triple spring. They usually get chewed up. I dont remember the last time i had seals. Remember our 300' pass is ALOT longer than a 1/8 or 1/4 run. Stuff has more time to build heat.
obsessedtruck is offline
