how tight for roller cam button bbc
Old 01-04-2010, 03:36 PM
  #1
ejm
SENIOR BUILDER
Default how tight for roller cam button bbc
i have a hubert solid roller cam just needing to know how tight to make the button on the cam or do i get it tight and back off or is it torqued
? thanks guys
ejm is offline
Old 01-07-2010, 02:51 PM
  #2
JimmySmith
Default nose button
I like mine .006 -.008 on a SBC .Later J.Smith 4621racing
JimmySmith is offline
Old 01-07-2010, 02:53 PM
  #3
fla1976
fla1976's Avatar
Here is a site that has some info for you.
http://www.chevyhiperformance.com/te...lay/index.html
fla1976 is offline
Old 01-07-2010, 03:54 PM
  #4
zipper06
I think he is asking how tight to to make the bolts on the cam gear. If that the case the bolts are 5/16"X24, and should be torqued to 25 lbs.
zipper06 is offline
Old 01-07-2010, 05:12 PM
  #5
JimmySmith
Default old folks
Thanks Zip for straighting out us old folks. I reread it and I think I misread this. Later J.Smith 4621 racing
Old 01-10-2010, 12:43 PM
  #6
ejm
SENIOR BUILDER
jimmy you were right i was wanting to know what is tollerable movement for the cam thanks for the response
ejm is offline
Old 01-10-2010, 02:01 PM
  #7
Tod74
I just make sure mine has a very slight amount of movement...I have no way of mounting an idicator on it with the cover on...can't get to it from the back on my engine stand.
Tod74 is offline
Old 01-12-2010, 01:37 PM
  #8
gungho
EXPERT BUILDER
Tod74,you do this by wiping a little grease in the inside of the the timing cover and the timing button,you than stick a little ball of modeling clay on the button,torque down the cover,remove the cover ,than check the thickness of the clay with your micrometer and keep shaving the button until you are where you want to be,thats how I do mine anyway.
gungho is offline
Old 01-12-2010, 03:43 PM
  #9
Tod74
THANKS,I'll try that.
Tod74 is offline
Old 01-12-2010, 03:48 PM
  #10
gungho
EXPERT BUILDER
also make sure you,loosen,or remove all your rockers... :wink:
gungho is offline
