The right sbc for the job, stroker or no
#1
APPRENTICE
Guy's, I have a 1962 ford falcon with a sbc 350 in her, about 380 hp at the wheels 420 ft lb torque. The car has a 350 gear and 2500 torque converter and weight is 3180 lbs. This is a street rod with an occasional pass. I want enough torque and hp to make the car quick in the 1/8 but drivable. I am looking hard at sbc 427.
Any help thanks:
Any help thanks:
#3
It may be cheaper to take that 350 and put a low profile Blower on it.
9:1 static compression recommended
Blower cam 114 lobe speration
run ya 6 to 8 lbs of boost thru it and Cometic head gaskets will be fine.
The Hp is gonna go close to 500 and the TQ will be a nice flat Curve possibly passing the 600 ft lb mark.....a natually aspirated 427ci will not produce a flat Tq curve like this 350ci blower set up will.
if you price the Blower job out wisely.you could get out for under 2,000-2500 (tops)
$1100-$1200 for used b&m 144 blower ( u can find them for this price)
$400-$500 for blower cam and roller hydraulic lifters
$200 set of cometic head gaskets.
$150 head studs
Could be another $300 to $400 to have your chambers opened on your heads to lower compression if your higher than 9:1 compression..if not this is money you do not need to spend.
then if you wanted up the anti on up..you can place a E-85 carb on top and make another 10-15% hp and Tq.
just sharing what i would do instead of dumping the heavy cash in a new 427ci...to do a 427ci SBC The right way is gonna cost you 7k to 10k
$150 head studs
__________________
Bjuice..
"I'M YOUR HUCKLEBERRY ! "
Bjuice..
#4
EXPERT BUILDER
buy some nitrous...i love the stuff, just took it out on street today....yea it was pulse pounding even at a small dose
if u just looking for a once and a while fix(like me) then its the way to go for cheap.blowers and turbos are nice but a lil more expensive but power is always there
#7
Hero or Zero
the blower he would have it at his command all the time ( power on tap)
the Blower would be the better route on a street car IMO......
Now in a all Race car i prefer Nos over Blower anyday...just because you can use the Nos as a chassis tunning device...a blower is total opposite.
__________________
Bjuice..
Bjuice..
#8
APPRENTICE
Thanks, Guy's for the advise. I am old school all motor type and already ordered a SHP block for the stroker. I don,t think that this 350 would stand a blower as it has cheap parts, not going to be the case with the stroker.
#9
I would limit the stroke to 3.875", 4" requires a fair amount of grinding and a real small base circle cam. Eagle has some stroker rods that are well clearanced for the cam. 4.155 bore puts it at 421, the difference from a 350 will definitely scare you first time out. And so you know, I have a 427 in the garage, built a 447 last year and have a 461 in my car now, I have an idea what it takes to build a stroker SBC.
#10
Curtis
