AIR BAGS
Old 09-11-2009, 03:00 AM
  #1
JEFF69Z28
DYNO OPERATOR
Default AIR BAGS
86 MONTE CARLO SHOULD I INSTALL BOTH OR JUST ONE ON THE RIGHT SIDE OF THE REAR END
JEFF69Z28 is offline
Old 09-11-2009, 08:13 AM
  #2
Tod74
My opinion is right side only is all you need. You need to preload that side since that wheel is trying to lift off the ground. I suppose two would let you adjust more but I always ran 1 in my Chevelle.
jmo
Tod74 is offline
Old 09-11-2009, 08:29 AM
  #3
JEFF69Z28
DYNO OPERATOR
Originally Posted by Tod74
My opinion is right side only is all you need. You need to preload that side since that wheel is trying to lift off the ground. I suppose two would let you adjust more but I always ran 1 in my Chevelle.HOW MUCH AIR?
jmo
  #4
JEFF69Z28
DYNO OPERATOR
HOW MUCH AIR SHOULD I START OUT WITH?
Old 09-11-2009, 09:44 AM
  #5
Tod74
7 -8 LBS IF I remember correctly. It's been a long time since I ran that car.
Tod74 is offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
