i swear im bout to just give up
#1
EXPERT BUILDER
this just sux
ive built quite a few motors but the only ones that always f**k up are mine.......i dont even get it
just finished my 383 had copper head gaskets on it, so i siliconed the water jackets, and i was not stingy with the silicone cus i didnt want no leeks. but guess what.......got water in the oil and water leakin from the pasenger side head gasket. i dont even know if its worth it nemore
but my question to yall is.......do i need to buy new gaskets or can i reuse the copper ones, ive never used them before so i dont know,
and if i can is there some kind of trick to siliconing these things, cus i have no clue what i may have done wrong
#5
Too MUCH Silly Cone might be your leakage prob.
ANYtime you use silicone, use it VERY sparingly. Too much and it just squeezes out into water/oil jackets/passages, as well as prevent proper compression/sealing of the gasket.
#6
Why are you bothering with copper head gaskets on a low compression street truck for? :? I have ran fel pro 1017-1 with 14 to 1 compression.
Just use regular FEL PRO GASKETS and make your life much easier. jmo
#7
Unless ur running a big blower or turbo you dont need a copper head gasket. Clean all the silicon out of your motor and put some fel pro on and be done.
I use the redish orange rtv on my coppers and dont have a problem and re used the gaskets many many times with no problems.
Are you using head bolts or studs?
#8
DYNO OPERATOR
[quote="bowhay"]this just sux
this is yo problem :arrow: and i was not stingy with the silicone cus i didnt want no leeks.
be stingy
be stingy
#9
EXPERT BUILDER
i used copper cus i needed a thick gasket
and i didnt glob the rtv on there. i just meant that i made sure to put a good bead around the water jackets,
but i still need to know, will that copper coat stuff take the place of the rtv silicone?
#10
A 4.200 x .046 ROL gasket is 10.2cc
A 4.200 x .051 FelPro is 11.2cc
Dave
