Aviation Fuel in a high comp engine
#1
I have a 415 sbc engine That has about 12.5 /1 comp. I would like to run it on the street and wondered if aviation fuel would be ok in it. I have been told yes and no. I have never used it but it is a lot cheaper than race fuel. :?
#3
#4
DYNO OPERATOR
About 14 years ago I lived 1 mile from an airport. I used to run aviation fuel 100LL (100 octane low lead) in a 13 to 1 BBC. Never had a bit of problem with it. Now I did have to go up (I think ) 2 jet sizes on my carb. Since 9-11 I don't know if they will still sell it to the public. If it's available to you, I wouldn't be afraid to run it in a 12.5 to 1 motor.
TS1955
TS1955
#5
I used to run it as it was cheaper than race gas and ran without problems. It is still avaiable, but is harder to find. Find a small private airport, they usually have it. The airport here uses Shell Fuels.
#8
#9
Bottom LINE!
Its FINE,i also use to run it ALL the Time in my 468"Chevelle back in the Late 70's Ealy 80's.
BUT.....................?
I ALWAYS would add some Type of Leaded Fuel,or Lead Additive.Its VERY DRY.
Later
G 8)
Later
G 8)
#10
Originally Posted by Tod74
http://www.yellowbullet.com/forum/showthread.php?t=125553&highlight=AVIATION+FUEL
http://www.yellowbullet.com/forum/sh...=AVIATION+FUEL
Here's two.
Here's two.
Still not the one I was looking for, someone took the time to explain what was missing in the stuff that makes it no good for us. I looked earlier today again and still couldnt find it. I do know a local used some and switched to torco 116 and picked up over a tenth 1/4
