inline diode from transbrake. why
#1
I'm new at this so I don't know anything about these diodes. I could'nt get my two step to work with my brake so I bipassed the diode that was in the line and it worked perfect. so what is the diode used for and is it a must. Thanks for any help.
Andy
Andy
#2
Not sure if it is the case with yours, but I have a diode wired up so I can back up, (pro brake), with a switch other than my normal transbrake switch and it does not back feed into the delay box starting the delay.
Curtis
Curtis
#4
I have a question...why is it a pro brake you need to hold a button to back up? what is the difference between a pro brake and the other? My powerglide has a COAN brake in it and I can back up just by putting it in reverse.
#5
dooracer I may have read your post wrong. are you saying you have two switches, one to back up with and one for the transbrake, or one switch with a wired in diode thats used for the transbrake and for backing up. Mine only has one switch. and now that i've cut the diode out I don't remember exacatly but would it go between the two step box and the button. and Todd I don't know that answer someone smarter than I will have to answer that.
thanks Andy
thanks Andy
#6
Member
MASTER JOURNEYMAN
With a pro brake, the fluid has 2 ways of releasing the pressure applied to the reverse, verses 1 way with a bracket brake. This is the reason a probrake gives faster reaction times.
#7
thanks Andy
thanks Andy
Yes I use 2 different switches, one for launching and a different switch for backing up. The reason I use different switches is the one for backing up is not momentary so I can use both hands and I don't have to hold the transbrake switch down. I am not exactly sure how yours is wired or what it was used for I just added what I use one for.
A pro brake also keeps you from getting the car into reverse on the big end if you put it into neutral because the solenoid has to be energized even if the shifter is in the reverse position.
Curtis
#8
Ok. Thats what I thought you said. and that sounds like a great Idea. my other car and this one now I bought both cars already built and they were both the same one button for the transbrake and reverse. but now what you are saying about the reverse makes alot of sence how would the two step know not to activate the transbrake when your only wanting reverse. this car may have had two switches and the man took one out being he was not useing the brake anymore. this switch worked perfect for reverse but it would not stall at the chip size. it would stall at the converter size at 5500 rpm. now that I cut the diode out it will stall at what ever chip I put in it. But I have not tryed reverse yet.
Thanks for all yalls Help: Andy Byrd
#9
DYNO OPERATOR
I've thought about installing a relay to do the same thing, but a diode would be much easier. Does having the diode in the circuit change the delay you run in the box? I'm sure there's some resistance through the diode and was wondering if it would have any effect.....
Johnny
Johnny
#10
Johnny
Johnny
Curtis
