'Glass body mystery....
Old 06-19-2009, 03:37 PM
  #1
TheYellaBrick
TheYellaBrick's Avatar
Default 'Glass body mystery....
http://blog.cardomain.com/2009/06/19...d-in-junkyard/
TheYellaBrick is offline
Old 06-19-2009, 03:47 PM
  #2
THERATTLER
THERATTLER's Avatar
THAT HAS TO BE AN EARLY COUPE PROMOD THAT DIDN'T TURN OUT RIGHT OR SOMETHING,,,,IT STILL HAS ALL THE MOLD EDGEING IN THE DOORS , , WELL,,,THATS WHAT IT LOOKS LIKE TO ME ops: ops: ops:
THERATTLER is offline
Old 06-19-2009, 05:31 PM
  #3
andamo
I'll bet that is the buck that Carl Moyer had made of a '38 Chevy to be used in the early Pro Mod days. At first I thought it might have been Scotty Cannon's Willys, but then I noticed where a side "window" should be.
andamo is offline
Old 06-19-2009, 06:49 PM
  #4
Tod74
pardon my ignorance....but WTF is a "buck" Is that the mold the body is made from?
Tod74 is offline
Old 06-19-2009, 09:27 PM
  #5
TheYellaBrick
That is correct, Tod. It's quite an interesting multi staged process to produce even a single part in 'glass or any composite.
You start with a 'master' or 'buck', which is exactly what you want to reproduce. It is a 'male' and is braced and supported to prevent any distortion. The 'buck' is usually used only once and that is to form the 'female' part of the mold. That 'female' mold is severily braced and built very strong to prevent distortion as it will be used many, many times to produce the actual parts that will be used.
Body bucks are kept as they can be modified to produce a slightly different female mold for a slightly different part. and on and on......
Old 06-19-2009, 11:23 PM
  #6
MEMRACING62
ONCE AGAIN I LEARNED SOMETHING NEW :!: :idea: :idea:
MEMRACING62 is offline
Old 06-21-2009, 05:02 PM
  #7
rob41willys
SENIOR BUILDER
I was thinking 37 chevy promod? Where's the front end? Carbon fiber anyone!!
rob41willys is offline
Old 06-22-2009, 11:22 AM
  #8
CamBirdRacing
DYNO OPERATOR
Helped a guy build boat mold this way. I didn't do any of the fiberglass work, I did the framing to stiffen the mold around it. Lots of box tubing a wire feed welder wire.
CamBirdRacing is offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
