how to turn on shift point with a biondo box
#1
APPRENTICE
've been running a mega 450 box for the past year with no problem. I decided to install co2 shifter and now need the shift point option in the box. I've read the 20 page book and configured the wiring correctly (I think) in test mode I can get the it to shift once , again this is in test mode per manual. when I toggle through modes I get to the screen that displays what’s on and off and the shift point is always off can anybody correct what I’m doing wrong ? or would a separate rpm activator box be the way to go?
#2
This topic just came up in another thread and it was mentioned that using the delay box to activate the shifter is illegal in NHRA AND IHRA...so IF you plan to run either of those you may want to use a seperate rpm switch such as MSD.
#3
Is it a powerglide? You only need it once.
#4
#6
OOPS.
ops: I guess I misunderstood, sorry.
Whats sad is, it seems like weekly someone at local race tracks argue with me that they can shift the car with the delay box by rpms, I explain no, no tach can be hooked to the box it is illegal. They dont understand and prob never will untill they so somewhere that actually techs a car.
