power glide leak
Old 06-08-2009, 06:06 PM
  #1
trucksrus
SHOW GUEST
Default power glide leak
newly build power glide after 5 runs started leaking at seal. this is a shorty.
trucksrus is offline
Old 06-08-2009, 07:01 PM
  #2
dparker
Front or rear?
dparker is offline
Old 06-08-2009, 09:20 PM
  #3
zipper06
Like Parker says, front or rear. I'm assuming the front seal, it's possible that the bell housing is not centered with the crankshaft. a lot of people never check the runout of the bellhousing with the crankshaft, that's one of the reasons they sell offset dowel pins to correct the problem. It's usually a converter problem, the hub is not concentric with the converter. If it's more than .005 there's a good chance it will leak when it's parked. been there and done that.
zipper06 is offline
Old 06-09-2009, 06:53 AM
  #4
oldandtired
oldandtired's Avatar
When rebuit was the torque converter bushing (sleeve) checked or replaced? A new seal will last a short period of time, but not long.
Dave
oldandtired is offline
Old 06-09-2009, 09:58 AM
  #5
dparker
X2 zip, If the back seal you probably don't have your motor saddles in the right position. Your coupler from the trans to the rear end should slide back and forth easily while the car is sitting still. If not you'll be putting your rear seal in a bind..could make it leak....
dparker is offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
