alky vs gas
Old 05-23-2009, 09:20 PM
  #1
Timmyboy86
Member
CRAFTSMAN
Default alky vs gas
once it's all said and done is it cheaper to run alky or gas?
Timmyboy86 is offline
Old 05-23-2009, 09:47 PM
  #2
dparker
Alcohol, as long as you have a source where you can get alcohol for $150.00 a barrel or cheaper.
dparker is offline
Old 05-24-2009, 01:54 AM
  #3
Tod74
how does it compare if you factor in extra maintenance and more frequent oil changes etc? That isn't me arguing by the way, I'm just asking.
Tod74 is offline
Old 05-24-2009, 04:59 AM
  #4
hammertime
Hey Tod,
There is NO extra maintenance when you have your setup right. Its not alky thats hard to use its people using it who make it harder then it should be.
I change oil same as gas, I run no top lube, check valves same as on gas (at oil change) have NO milky oil and looks great when it comes apart.
hammertime is offline
Old 05-24-2009, 05:05 AM
  #5
Tod74
I have a couple of friends who run the Ron's terminator setups and they love them. Both cars are very consistant...they never mess with theirs either...but they run vaccume pumps too.The guys I know runing carburators have issues with milking the oil and change the oil just about every week....
Tod74 is offline
Old 05-24-2009, 06:12 AM
  #6
hammertime
Must be ruperts :wink:
I've never had a issue with alky when I ran apd's, ruperts were always milky and looked like crap.
Old 05-24-2009, 08:07 AM
  #7
THERATTLER
THERATTLER's Avatar
I'M WITH HAMMER . ALCOHOL IS ABOUT A 1/4 THE PRICE OF RACING GAS RIGHT NOW...I RUN AN ENDERLE HAT ON A BLOWER WITH NO MILKING AT ALL , PEOPLE THAT HAVE MILKY OIL ARE RUNNING TOO RICH. I CAN RICHEN UP THE BARREL VALVE TO STOP THE IDLE HUNT AND MILK UP THE OIL..I HAVE BEEN RUNNING ALCOHOL FOR YEARS WITH NO ENGINE PROBLEMS WHAT SO EVER ,I ALWAYS SHUT DOWN MY ENGINE ON GASOLINE AND SPIN IT OVER WHILE SPRAYING WD 40 IN INJECTOR IF IT IS GOING TO SIT AWHILE. STOPS CORROSION.
THERATTLER is offline
Old 05-24-2009, 08:21 AM
  #8
Tod74
My friends do the same( run on gas before shut down) Also use a gas primer set up
Tod74 is offline
Old 05-24-2009, 08:30 PM
  #9
Timmyboy86
Member
CRAFTSMAN
maybe i should have been more specific i was trying to compare alcohol to pump gas not race gas
Old 05-25-2009, 05:42 AM
  #10
hammertime
no comparsion !
