Oil pan change: SBC in 70 Chevelle
Old 05-15-2009, 12:11 PM
  #1
mep
JOURNEYMAN
Default Oil pan change: SBC in 70 Chevelle
Question: Is there an EASY way to change out the oil pan in a 70 Chevelle with sbc? There doesn't seem to be enough room to clear the front crossmember without loosening the motor mounts and raising the motor itself? Any ideas/suggestions? Thanks. Mep
mep is offline
Old 05-30-2009, 04:25 AM
  #2
whitey70ss
thats what youre gonna have to do! I went through the same task not long ago.
whitey70ss is offline
Old 05-31-2009, 10:23 PM
  #3
ashbros
x2 just go ahead and do it. you'll be done before u know it.
Hope you are putting a good pan on and you might consider changing the oil pump when you do...........
ashbros is offline
Old 06-01-2009, 04:21 AM
  #4
Tod74
I'd just pull the motor and be done with it....
Tod74 is offline
Old 06-01-2009, 04:53 AM
  #5
suicidebomb
What he said........
suicidebomb is offline
Old 06-01-2009, 06:12 AM
  #6
kbartley
EXPERT BUILDER
Default YEP!
Yep!!! X3 pulling the motor is actually the easier route. What if you do it the other way & have a leak when you're done. Been there, done that, & It tissed me off!
JMO,
Kris
kbartley is offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
