bbc question
Old 05-06-2009, 07:25 AM
  #1
taps
Member
JUNIOR BUILDER
Default bbc question
what is minimum piston to head clearance on steel rod bbc?
taps is offline
Old 05-06-2009, 08:07 AM
  #2
TS1955
DYNO OPERATOR
I typically run "zero" deck clearance and a Felpro #1027 head gasket which has a compressed thickness of .039. So my piston to head clearance is .039. Hope this helps. I'm sure others do it differently.
TS1955
TS1955 is offline
Old 05-06-2009, 09:46 AM
  #3
curtisreed
curtisreed's Avatar
Watch your piston rock depending on how "big" your BBC is. RPM will also play into it some. Just some things to think about in the equation.
Curtis
curtisreed is offline
Old 05-06-2009, 01:28 PM
  #4
ARUSSELL
We recommend a min of .040 between the piston and the head.
ARUSSELL is offline
Old 06-17-2009, 10:00 PM
  #5
russ67chevelle
EXPERT BUILDER
my motor builder said once upon a time they set up thier pistons .005 thousandths in the hole
russ67chevelle is offline
Old 06-18-2009, 03:52 AM
  #6
curtisreed
curtisreed's Avatar
russ,
That doesn't tell you what the p to h clearance is. You could still have .060".
Curtis
Old 06-18-2009, 05:01 AM
  #7
dparker
Plus the gasket....
dparker is offline
Old 06-18-2009, 01:24 PM
  #8
desoto30
Member
JUNIOR BUILDER
I think russ67 meant .005" = a "std" style gasket say 0.039" compressed & you'll generally be ok. X2 As doorracer says depending how "big" & rpm. I don't understand the last post.
desoto30 is offline
Old 06-18-2009, 06:32 PM
  #9
dparker
I dont see what would be hard to understand. .005 in the hole plus the gasket .039 would give you .044 clearance, between the flat part of the piston and the head. Which is where most pistons hit. Especially if because of the piston rocking in the cylinder.
dparker is offline
Old 06-18-2009, 06:35 PM
  #10
Tod74
Mine hit on the dome right by the intake valve...Motor was already together so I had to grind on a brand new set of heads.
Tod74 is offline
