Stock powerglide case
#1
SENIOR BUILDER
What can a stock powerglide case hold up to in regards to hp limits? How much does an aftermarket bellhousing (i.e. an Ultrabell) improve upon that, if any?
Thanks
Mark
Thanks
Mark
#2
Thanks
Mark
Thanks
Mark
IMO if your going to spend the money buy the entire case, it'll be worth it in the end.
#4
I wouldn't be too concerned about the case. You need to make sure the guts and convertor are built to handle it. You can always put a blanket on the case and sheild the bellhousing.
#5
I have a stock powerglide case behind a 540 in a 3200 lb car...Stock planets and all. It has a COAN shaft and transbrake in it along with a good servo thingamajigger but the rest is factory junk....knock on wood no trouble so far.
#8
I ran a stock case with a TCI planetary and guts in a 3500 lb door car with a 600+ HP SBC engine for the better part of 9 years and never hurt a case.
Had two dragsters, one 482 BBC and one 434 SBC with stock cases that worked fine.
I've built a s**t load of'em, including one behind a 496 BBC in a door car that have had zero case problems also. Ya have to realize that the load on the gearset is internal and there is very little radial jor axial force involved.
If that's what you got, then run it!
