Tubes in Micky T's ET Drag
Old 04-23-2009, 10:19 AM
  #1
Pdmracing
Member
CRAFTSMAN
Default Tubes in Micky T's ET Drag
New to this game, Summit & mickey T says to run the tubes, but RJ race cars book says no way? what do you do?
thanks
Pdmracing is offline
Old 04-23-2009, 04:39 PM
  #2
BEAST477
BEAST477's Avatar
I've got tubes in mine. No problems. Running low 9's.
BEAST477 is offline
Old 05-04-2009, 11:40 AM
  #3
johnracer
DYNO OPERATOR
Tubeless for sure. They'll work better.....but they do leak. I run Goodyears tubeless too.
Johnny
johnracer is offline
Old 05-04-2009, 12:26 PM
  #4
fla1976
fla1976's Avatar
Default Tubes
I ran my Hoosiers tubeless and coated the complete inside of the tire with Ivory soap before mounting them. The soap seals the tires without adding weight and never had a problem with the tire leaking down. It's an option.
fla1976 is offline
Old 05-04-2009, 12:28 PM
  #5
Tod74
I've ran both. Car worked the same either way, but Tubes are pretty heavy.
Tod74 is offline
Old 05-04-2009, 01:29 PM
  #6
dparker
Tubeless all the way. lod school for me no rubbers.
Tubes seem to push on the center more.
I would say whichever you prefer will be just fine........Works both ways.
dparker is offline
Old 05-14-2009, 02:03 AM
  #7
chevyfireball
Depending on how big your tires are, tubes can effect the way the tires wrinkle on launch. I'd run tubeless if possible.
chevyfireball is offline
Old 05-19-2009, 07:24 PM
  #8
68bbnova
Member
MASTER JOURNEYMAN
I have some steel rally rims I ran tubes in, but now I want to try tubless. What valve stem would I use, now that the hole was drilled to 1/2" ?
68bbnova is offline
Old 05-20-2009, 02:38 AM
  #9
I972Nova
EXPERT BUILDER
You can get valve stems at Jegs or whereever that will work in a .453 or .625 hole. These are what I had to get with the wheels on my truck, the guy I got them from used tubes.
http://www.jegs.com/i/Detroit+Wheels...900-4/10002/-1
I972Nova is offline
Old 05-20-2009, 06:03 PM
  #10
68bbnova
Member
MASTER JOURNEYMAN
Thanks, Its been a long time since I bolted in all my valve stems, and could not remember how they sealed.
68bbnova is offline
