bbc motor work?
#5
Originally Posted by CamBirdRacing
Have it sonic tested, most can go .060 over safely. Do that and put a 4.25 stroke crank in it and build a 496.
#7
JOURNEYMAN
Originally Posted by rhiasdaddy
just checked the numbers on my block and it is a k block
#8
Do You Already have a NEW Set of +.080 Pistons???
If Not,Why would you take a Standard Bore Block and Bore it .080?
Do you know How much Performance you will Gain with the .080 Bore over Standard???
I DO?
VERY LITTLE!!!
Later
G 8)
If You have a Nice Standard Block,KEEP IT THAT WAY!
I Have a REAL Nice +.125 Over Block that is already Done,Hard Block,Studs,O-Rings,Line-Hone,The Whole 9.And i'm Sure i'm NOT the Only 1?
THINK ABOUT IT.................................. :?:
I DO?
VERY LITTLE!!!
Later
G 8)
#9
#10
Member
JUNIOR BUILDER
As radicalz stated above,when you change the bore and stroke of the 454,you need to plan out which cam profile you are going to use.Many years ago,I took the ls6 motor out of my 1970 el camino and increased it to 496''.Alot of changes were needed,but with that stroke increase,the torque of the motor really put me back in the seat.Take your time and plan it .It will be worth it.FISHMANJOE
