Just Checking Anyone delt wit alan2387
#1
:?: Never delt with this guy and he does not have a race space profile.
Let me know. :?: Looking for good guys to deal with.
Thanks, ashbros
Check out some of the replies:
From: alan2387 To: ashbros Date: 2009-02-02 19:43:39
Subject: Re: MOTOR
Re: Ad #1451811 - GM CHEVY BOWTIE BLOCK 9.800 DECK 4.530 BORE
I WANT KNOW THE COMPRESSION, IS FOR MY PRO STREET CAR, AND I WANT RUN WITH PUMP GAS, OR AIR PLAIN GAS,
IF YOU HAVE NUMBER OF PISTON AND CC COMBUSTION CHAMBER TO YOU HEAD, I CAN CALCULATE.
On [2009-02-01 22:18:27] ashbros wrote:
> 4340 it is marked as such
> On [2009-02-01 21:39:40] alan2387 wrote:
> > I WANT MAKE SURE
> > is 4340 steel crank made by GM is not 5140
> > On [2009-02-01 21:21:19] ashbros wrote:
> > > Engine Displacement is 515
> > > GM Steel Crank 4340 4.000 stroke Externally balanced motor
> > > Eagle H-Beam Rods 6.385
> > > SRP flat top pistons 4.530 bore
> > > Piston and Cylinder bore is clearanced per piston specs
> > > There is only 4 dyno runs on the block and rotator. Engine made 851 hp on dyno with pro 1 345 6/71 blower with only 4.5 lbs boost
> > > I really do not want to sell the block. I would really like to keep it for a nice spare, but I just spent 22 grand on a new Aluminum Block, rotator and pro charger system. Just trying to get a little toy money back in my pocket.
> > > On [2009-02-01 21:12:58] alan2387 wrote:
> > > > I AM INTERESTED TO YOUR COMPLETTE SHORT BLOCK
> > > > WHAT DO YOU HAVE
> > > > CRANK: STROKE, MADE, STD,
> > > > ROD: LENGHT, MADE,
> > > > PISTON: COMPRESSION, OR NUMBER,
> > > > YOUR ROTATING FIT PERFECTLY IN YOUR BLOCK (GAP BETWEEN PISTON TO WALL)
Thanks, ashbros
Subject: Re: MOTOR
> > I WANT MAKE SURE
> > > > WHAT DO YOU HAVE
> > > > ROD: LENGHT, MADE,
#2
Sounds like some Nigerian reeling you in with small talk. Play it out VERY carefully and give ZERO personal info, and DO NOT open ANY links in an email he may send you !! NONE !! ANY addy he sends, write it down and type it in your browser, DO NOT open directly, DO NOT copy and paste. Keep copies of EVERYthing !
#4
Where is he from? If this is Alan R. from Jacksonville FL., I have raced with him for years and I think what he tells you is straight up. I didn't list his last name just in case it's not the same one.
#5
I know nothing about this guy or where he is from. Not saying he is a bad guy, nothing like that just want to know who I am dealing with.
No harm meant, and no harm in asking
#6
