Cam recommendation for 652 BBC
#1
APPRENTICE
Fellas (and ladies),
I am into my first attempt at a larger cubic inch Chevy and need cam advice. My block is an older Donovan 11.100 that cannot be bored for large cam journals. Engine will be used in lighter dragster with powerglide and 33 inch tall tires. Estimated total weight 1650 lbs (???)
Engine specifics are 652" BBC with 18 degree Dart Big Chiefs with full CNC port and titanium vlaves (2.400 /1.900). Compression at 15/1. Crank is 5.100 stroke.Bore is at 4.510. I would like to run 2 Dominators on sheet metal intake (gas- no nitrous). I would like help with a cam selection and don't need something that will "kill" the springs and valvetrain. Basically, my hope is to come out with a large inch, lightweight package that makes good power without having to turn the unit excessively. I am OK with sacrificing some power in trade for reliability.
Thanks in advance..Tom
Danville IN
Danville IN
#2
APPRENTICE
Hello, I have built many big chief 622, 632, 706 BBC engines. Most of them with sheetmetal or cast tunnel rams with 2X4 4500 carbs. I use Erson or Comp cams mainly and most of the time custom grinds. Here is a grind I use often for a 622, 12 Degree, 2X4, dry sump, natrually aspirated drag race engine, corrected dyno figures for this engine are 1260HP & 925ft/lbs. Cam is mechanical roller, 4-7 swap, Duration @ .050": INT288/EXH308, Lobe Lift: INT.495"/EXH.475", Lobe Separation Angle: 114. Thanks.
#4
APPRENTICE
Tom,
Actually I do have some custom grind Erson cams on the shelf. If you are looking for a custom cam that will perform in a large cubic inch displacement BB Chevy with big chief style heads, I have another spec grind that I work specifically with Erson on and this particular grind has a lobe design that is less aggressive and more spring and valve train "friendly". I have many hours in R&D on the dyno with different cam profiles and this is one of my favorites. This cam is used in 14 & 18 degree Dart big chief 572-605-632 bracket engines. Cam specs are: 4-7 Swap Firing Order, Duration @ .050": INT284/EXH298, Lobe Lift: INT.475"/EXH.450", Lobe Separation Angle: 114. These cams are in stock ready to be shipped. Price is $339.99 + shipping. Email: [email protected] or call 307-322-2062.
Thanks, Sean
Thanks, Sean
#5
as you need more info try clay smith engineering "mr. horsepower"
@ www.claysmithcams.com that might be it or it will guide you
to the correct website, hey get well informed and get all your
options, i like to talk to guys that all they do is grind cams,
my first was a chet herbert, good luck :wink:
#8
APPRENTICE
Fellas,
Thanks for all the input. I bought this car from the second owner and it weighed in at 1350 with an iron small block and driver. Car is a 250" RED that was built in Bob Meyers shop and is a 100% knock-off of Rick Santos legendary small block alcohol machine. Mag floater rear,no paint and black anodized panels to keep weight in check.
BTW..I'm offerring my 1st motor I built for the car but never used. If anyone wants a great 565 Big Chief (1021 hp /795 ft.lbs) give me a shout (or search 565 Big Chief on this site) I've just got the hanker'in to go a bit faster and the aluminum motor appeals to me.
Kind Regards,
Tom Timmermann
Danville IN
Kind Regards,
Tom Timmermann
Danville IN
#9
Originally Posted by turbinetom
Fellas,
Kind Regards,
Tom Timmermann
Danville IN
Kind Regards,
Tom Timmermann
Danville IN
#10
Tom nice looking 565ci..just curious,,ya got a Nos cam or something in that 565ci...1021hp seems a little low on that engine with those Big chief heads...i am thinking 1140 to 1150 ?
good luck selling ! and with your new project
__________________
Bjuice..
"I'M YOUR HUCKLEBERRY ! "
Bjuice..
