oliver or bill miller rods
#1
Which rods should I use in a 632? It will be used to drive about 2 miles on the street to cruise nights 2 times a month and race at the track maybe 7 times in a year. The car will be mostly a show car but it will still have about 1200 hp on motor. If I use oliver rods I will use diamond pistons and if I use bill miller I will use his pistons. I had the car two years and I only put about 400 miles on it and 300 of that was in the first month.
#5
Originally Posted by jmarksdragster
Unless you plan to run extreme RPM's stick with steel. Oliver, Carillo, Crower, any would work.
X2 all my td/ts buddies replaced alum rods every winter, some before that. Which seems to be common thing with alum rods. A steel rod you dont worry about that.
#7
Originally Posted by bbchevy
I'd BUY a EAGLE before the OVER PRICED JUNK THat OLIVER SELLS!!!!!
I have 2-New Billet Olivers Here to Prove what i'm Saying!!!!
Later
G 8)
Later
G 8)
#8
I have Oliver's in my SB2 and no issues, the only thing I would recommend is to upgrade the bolts on any of the brands. Getting ready to order a set for a 460ci small block with SB2 heads. Should be $1300 plus the bolt upgrade for big block Oliver's.
