512 code
Old 10-04-2008, 09:00 AM
  #1
chev514
SHOW GUEST
Default 512 code
I am looking at purchasing a 73 corvett block. The guy sas the numbers on the front pad ------512 and there is a ce stamped on the block witch he sas is corvett replacement. It is a 4bolt main. I know older blocks like that were ls6 blocks any help would be apreciated.
chev514 is offline
Old 10-04-2008, 02:24 PM
  #2
Tod74
The 512 was the casting number of the LS-6 blocks but not the number on the pad...I have 2 512's one has been decked(can't read the pad on passenger side) the other was an ls5 and if memory serves it has CRT . Any old Chilton book will tell you , let me go do some looking and I'll post it.
Tod74 is offline
Old 10-04-2008, 02:51 PM
  #3
Tod74
SORRY IF THEY ARE HARD TO READ...TRIED TO SCAN IT BEST I could....don't know about corvette replacement but just about all the codes in the book are 3 letters
Tod74 is offline
  #4
Tod74
Tod74 is offline
Old 10-05-2008, 05:28 AM
  #5
john858
EXPERT BUILDER
i've been through this with a 70 chevelle that i had the ce stands for crate engine. my was a replacement engine that was put in from chevy under warranty from what i understood.hope that helps ,john
john858 is offline
Old 10-05-2008, 06:20 AM
  #6
fla1976
fla1976's Avatar
Default CE
I have a similar engine in my garage on the stand. The original number is still on it and is "Xed" out. It is still legible and translates to a 64 corvette hipo 327. The CE is just documentation that the original was a factory warranty and the engine was replaced. The original was then rebuilt and sold as a replacement crate engine. It is probably a great engine that you have as they probably got it right the second time around.
fla1976 is offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
