Oil Pans & HP
#1
Hey guys this has been talked about several times I am sure but how much HP is there to be had in oil pans ?
I've ran a regular moroso pan for years but wondering if I should be looking at others ?
thanks
thanks
#3
I don't know how HP can be picked up in an oil pan, but going dry sump there's definately some good gains. There's definately some gains by cutting down on the oil pressure and running thinner oils. i know people running 0-30 oil and gained as much as .005, but that's with a S/blk. By the way my friend with the old 49 ford truck not chopped with stock frame and ladder bars, got some new tires and ran 5.39 friday no additives. That's a 572 rat on gas and over 3,000 lbs with all glass and roll up windows.
#5
DYNO OPERATOR
David, in my opinion, if you have a very high rpm combo, then you would probably see gains on a dyno with a really good pan. I'd say maybe 8-10 hp. If you had a really crappy pan before, maybe more. On the track, especially in a fast car like yours, I don't think you'd see any improvement at all. For what a trick pan costs, you could find more cost effective power gains elsewhere.....jmo
Johnny
Johnny
#6
thanks for the replies guys
Like the last post said is what I figured there are better places to spend the money to make HP. Not that I need a ton more just looking for another 50hp without doing much to the motor. 8)
#9
My concern with an oil pan is to make sure the proper oil pressure is maintained throughout the run. Some pans on certain applications do not allow proper windage and oil return for pump pick up resulting in low oil pressure around 1200 ft mark. Now that a scary moment.
I have found the moroso and old hamburger pans work great for my seranio.
