Crankcase Evacuation System
Old 07-22-2008, 03:09 PM
  #1
prostreet1972
Member
JOURNEYMAN
Default Crankcase Evacuation System
I bought a Crankcase Evac. System from the last swap meet. I have a couple of question on installing it. First what hose should I use?? Is the clear tubing the sell at Lowe's good enough or will it just melt. Also have far into the exhaust should the fitting stick out?? any trick on where and how for the header/exhaust I should install it? This is being install on a 72 chevelle.
Thanks,
Travis
prostreet1972 is offline
Old 07-26-2008, 01:36 AM
  #2
PHUCKYOU247
SHOW GUEST
http://static.summitracing.com/globa.../mor-25900.pdf
Add a cut like this for a better result
PHUCKYOU247 is offline
Old 07-27-2008, 06:25 AM
  #3
manley
Member
JUNIOR BUILDER
Ive used that clear hose before, did have any trouble at all!
manley is offline
Old 07-27-2008, 07:59 AM
  #4
Tod74
I use -10 braided with an AN fitting on the valve cover and a hoise clamp on the header end.
Tod74 is offline
Old 07-27-2008, 09:21 AM
  #5
Racefab57
DYNO OPERATOR
Hell Ive used heater hose , worked fine ,even had the GM logo on it . I used the rest of it on a GM resto !!!! David.
Racefab57 is offline
Old 07-27-2008, 10:34 AM
  #6
zipper06
I too think heater hose is the common practice, unless you're in close qtrs, with the header tubes, then it's steel braided line but at 2 times the cost.
zipper06 is offline
Old 07-27-2008, 03:12 PM
  #7
hammertime
I use the clear with mesh dishwasher hose that you can get at any hardware store works great .
hammertime is offline
Old 07-28-2008, 08:24 AM
  #8
mudder81
JOURNEYMAN
Along with this topic, do you guys use breathers in the valve covers with the evacs?
mudder81 is offline
Old 07-28-2008, 10:16 AM
  #9
topcat572
Default evacs
NO.
topcat572 is offline
Old 07-28-2008, 11:30 AM
  #10
mudder81
JOURNEYMAN
Thanks, I thought I would ask.
mudder81 is offline
