Im stumped (coolant leak)
#1
DYNO TECH
while taking my car for a ride everything seemed fine.
upon returning I got out of the car to open garage door and parked the car.
I noticed a 1 foot puddle of coolant on the asphalt.
looking at the motor the pump and hoses all look tight but I got a steady stream of coolant dripping from the bottom middle of the timing cover.
timing cover face looked dry.
I double checked tightness of pump and the weep hole and still could not find the source.
any ideas?
any ideas?
#3
DYNO TECH
its a 406 smallblock chevy.
I found the problem btw.
the water pump has a small pinhole in the casting.
called edelbrock and they had bad castings in the past so they are replacing it.
