JESEL BELT DRIVE
Old 07-13-2008, 03:45 AM
  #1
RAPPTOR23
Member
MASTER JOURNEYMAN
Default JESEL BELT DRIVE
HOW OR WHAT DO YOU USE TO GET THE BALANCER BACK ON AFTER INSTALING A BELT DRIVE?? STANDARD BALANCER ? :cry: :shock:
RAPPTOR23 is offline
Old 07-13-2008, 12:23 PM
  #2
Racefab57
DYNO OPERATOR
I just use the balancer bolt. Tell me more!!!! David.
Racefab57 is offline
Old 07-13-2008, 04:34 PM
  #3
sg1586
A Big FH!!!!!!! No only kidding :lol: ..There is a tool made to press it back on and I would not use the balancer bolt as it may pull the threads out of the crank..The Balancer bolt is only there to hold it from backing off the crank Not to use it to press it back on....
Some people are here to learn how to do things right. Not to make more problems for themselves....Lets try to give sound advice..
sg1586 is offline
Old 07-13-2008, 10:56 PM
  #4
Tod74
BALANCER INSTALLER.
Easy to make if you have access to a lathe. Big threaded thing that is turned down on one end to match the threads in the crank. Thread it into the crank then use a nut and heavy washer to push the balancer on.
Tod74 is offline
Old 07-14-2008, 02:31 AM
  #5
us7race
EXPERT BUILDER
Default Re: JESEL BELT DRIVE
This pic is the only one I can find quickly...
http://images.search.yahoo.com/image...3fkva9it&tt=37
Looks like just install the balancer after the belt drive is installed.
us7race is offline
Old 07-14-2008, 08:27 PM
  #6
zipper06
A balancer installer, atleast a good one goes for about $40.00 and has a roller thrust bearing on the front. You screw the center bolt all the way in and then pull the balancer on. It works the same way to remove the balancer. This way you have no chance of stripping the threads in the crank. If you mess with engines it's a good investment.
zipper06 is offline
Old 07-15-2008, 05:23 AM
  #7
olds48
A good(emphasis on GOOD) bolt and a long nutwill do just as good a job as a balancer installer.I bought two pieces of grade 8 all thread,one to match sbc and one for bbc,and two nuts for each.Welded a nut on the end of each and use the other nut to push with.Usually use several fender washers,along with the heavy damper washer,all of them greased,to help cut friction.Works fine,not pretty or impressive at all,but I got two balancer installers for under $10 Just a thought for the other tightwads like me!!
olds48 is offline
Old 07-15-2008, 03:32 PM
  #8
Racefab57
DYNO OPERATOR
Ive got a balancer installer from snap-on and it doesnt work nearly as good as my ARP bal bolt!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!! David.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
