pushrod length??sbc
Old 04-26-2008, 09:06 AM
  #1
corenele
SHOW GUEST
Default pushrod length??sbc
i just made a home made screw out style pushrod to check the length of the pushrod that i may need and i came up with 8 inch.that seems to be a little to long but thats what i measured.i have a solid roller and i think solid rollers lifters are a little longer than tapped lifters.the pushrods that came out were 7.7 i was just surprised to read 8 inches with the same block i have changed to a small base circle roller cam but put in longer crower lifters and new afr 210 heads that were the same cc as the old afr heads i just want to know if 8 is a normal size for pushrods i was expecting to read somewere from 7.5-7.7 not 8
corenele is offline
Old 04-26-2008, 12:06 PM
  #2
jmarksdragster
jmarksdragster's Avatar
Read the following.
http://www.mid-lift.com/What-is-ML.htm
jmarksdragster is offline
Old 04-27-2008, 04:09 PM
  #3
Tod74
Originally Posted by jmarksdragster
that's a good read.
I set mine up that way but strange thing is the exhaust came out with the pattern dead center but the intake it is on the header side of the valve tip...but at mid lift the center of the roller tip axle and the trunion are in line so I guess it's correct. ( BBC)
Tod74 is offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
