converter question
#1
Member
MASTER JOURNEYMAN
I filled my converter with fluid and installed it. I noticed it did not make contact with the tail end of the crank so I sent it back and they welded the extension on but they did not cut the converter open to do it. My concern is that the heat from welding the extension on did some damage. Any one know if this will be a problem. Thanks, Mike
#3
Member
MASTER JOURNEYMAN
bbchevy thanks, I would not worry but they had to weld it two times. The first weld was cold and the piece fell off. I sent it back to turbo action and had it welded a second time. Thanks, Mike
#4
#6
NOW,
=You did NOT tell Me about the Weld Job,NOT Holding?Thats Not Good!!!
Alls i can say,if I Welded it?It would Not Fall off,,or get enough Heat to Matter!
If you had that Prob.?I SURE HOPE THAT THEY PAYED THE SHIPPING,Both WAYS!
Later
G 8)
Later
G 8)
#8
what happened with the orginal build ?..if they knew the motor plate thickness..they should have got this snout length dead on the 1st time..
i have a converter that has the threaded snout so you run different length snouts on different thickness motor plates.
i would stay away from whomever built that converter..no excuse for the weld job.
IMO
IMO
__________________
Bjuice..
"I'M YOUR HUCKLEBERRY ! "
Bjuice..
