engine bearings SBC
04-04-2008, 02:30 PM
Member
JUNIOR BUILDER
engine bearings SBC
Would someone tell me the difference between the Clevite MS909P Main bearing and the MB2508P Main Bearing.
04-04-2008, 03:06 PM
The MS909P is a standard LJ350 main bearing. The MB2508 appears to have a .020 reduced width on the rear main, probably for a block that spun a rear main and required repair.
04-04-2008, 03:23 PM
Member
JUNIOR BUILDER
Thank you very much. I quess it would be smart to replace it with what I took out correct?
04-04-2008, 03:32 PM
Quote:
I would...unless of coarse what you took out wasn't working.
04-04-2008, 04:10 PM
04-04-2008, 05:22 PM
Member
JUNIOR BUILDER
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
