Top End vs Bottom End
#1
Member
MASTER JOURNEYMAN
I am looking for some advice and figured this is the best place to find it. I am finishing up my backhalfed S-10 project and am looking to add more power. It currently has a 360 SBC with 10:1 compression, a Comp Cam 292H cam, 64cc 2.02/1.60 Dart Iron Eagle heads and a Team G intake. But the bottom end is pretty much stock. The motor is backed by a powerglide with a break and a 5000 stall converter. I am running 32 inch rear tire and upgrading to a 5:13 gear. I am planning on running mostly 1/8th mile. My first question is would I be better off upgrading cam and heads or should I build a new forged short block and keep my heads and intake? If I go with the top end upgrade I was thinking about a Crane Cam F-290-2, which is 252/260 and Darts Pro1 215cc and keeping my intake. My second question is would this be the best combo or should I just build a 383 or a 406 or maybe a 414? I have a 4 bolt main 350 block for a 383 or a 2 bolt main 400 block for a 406 or 414 (or even a destroked 377). I will probably still use the Crane Cam in the new short block and keep my heads and intake. I would rather stay away from nitrous for now but it will probably be in the near future. Any thoughts would be great. Thanks
#2
If you are seriously considering going with nitrous, I would go for the bottom end first. I would probably go with the bottom end anyway as I have lost more engines due to bottom end failure than top end failure. I have run a 377 and was happy with it until a rod bolt broke. It was an ARP bolt and the next engine was run with ARP but beefier 7/16 over the 3/8.
#3
Build the best short block you can afford and you know you are covered whatever you decide to do to it later on down the road. Sink a ton of money in heads and break a rod or something and potentially lose all of it...or at least damage it.
#4
If you are buying an aftermarket block for the upgrade, go to a 421. You can go 434, but it's a bit of a pain. More grinding, smaller cam core, taller lifters.... With a 5000 converter, you can go about [email protected] on the intake for duration. With that CI you can back down the gear to a 4.56, or 4.88 if 1/8 only. If you have the 200cc iron heads you can make a lot of power with a roller cam, I ran 8.70's with a 406, 260/[email protected] Crane .625 roller, and a Super Victor intake/800 Holley on those heads in a 1750 lb dragster.
