tire?????
Old 01-13-2008, 03:11 PM
  #1
kw89425
Default tire?????
im going to run a 31x14x15 on my 2800lb car what would be the best tire and compound? mostly running 1/8 leaving between 4000 and 4500
kw89425 is offline
Old 01-13-2008, 05:33 PM
  #2
us7race
EXPERT BUILDER
Not sure about the compound but I would like to say my truck weight is 2750 and a Stiff sidewall slick works great. I had always thought they were for heavier cars but they do work great at 2750..Just a thought.
us7race is offline
Old 03-28-2008, 05:11 AM
  #3
Tod74
2750 with or without driver ?
Tod74 is offline
Old 03-28-2008, 05:41 AM
  #4
gearhead1011
EXPERT BUILDER
gearhead1011's Avatar
Go with the stiff sidewall, M/T told me the soft (regular) sidewall tires are for light cars with no rear suspension . I like the Mickey Thompson. They are real consistant and I get a bunch of passes out of them. The 31x14x15 will be the M/T part number 3074S and that's a stiff sidewall L8 compound. Follow M/T's instructions for checking/correcting rollout BEFORE you do the 1st burnout with them. With the weight of your car you'll probably start with around 6 lbs of air.
gearhead1011 is offline
Old 03-28-2008, 06:40 PM
  #5
Tod74
I run a 32 x 14 goodyear stiff sidewall on my Nova it is 2820 without me and 3050 or there abouts with my fat butt in it.Mine works good with 8 -10 pounds but I have never tried lower than 8 psi.
Tod74 is offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
