BBC HEADS ALUMINUM OR IRON
Old 10-29-2007, 05:12 AM
  #1
dizney4
SHOW GUEST
Default BBC HEADS ALUMINUM OR IRON
Going to build a 396 for a 69 Camaro. This will be a street car that will see the 1/4 mile maybe a couple of times a year. My goal is to get around 500HP. My question is should I put on aluminum or iron heads? And why? Thanks for your help.
dizney4 is offline
Old 10-29-2007, 05:43 AM
  #2
Tod74
Aluminum..With a big block chevy you will take 75 lbs off the car by going to aluminum heads.I also think you can get away with a little more compression with the aluminum vs iron. (pump gas)..not possitive about the compression but I have weighed BBC heads both iron and aluminum and the difference was 75 lbs on mine...
Tod74 is offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
