homemade launch pad/ glue
Old 09-24-2007, 07:42 PM
  #1
slagburn
SHOW GUEST
Default homemade launch pad/ glue
Say, in theory, there's a good sized chunk of asphalt (not concrete) nearby that a guy would like to give some traction, and there won't be a ton of traffic messing with any prep work.
Is it as easy as purchasing some vht track bite and a weed sprayer? I've heard mention that pouring root beer around works too..
How far does a gallon jug of trackbite go, and does it need diluted?
Thanks for any help.
slagburn is offline
Old 09-26-2007, 03:32 PM
  #2
jaykz1000
Member
MASTER JOURNEYMAN
all u need is some VHT .. on the vht less is more method works best ..if u get to much on the ground and cant burn it off then its just like water.. best if u have a car u can do burnouts with as well..pour u a small puddle out in front of the back tires and do a burn out threw it then back up and do one right next to it overlap just a lil then do a nother on the other side.. makes a nice rubber launch pad..if your not going to race right that second then go over your marks with a sprayer if u want and light on fire or let dry .. u can also light the VHT on fire if u have to much and cant burn it in the ground... if u plan on racing right then and there i just do the puddle and burnouts then race right after.. not that ive ever done anything of the like ...lol pm me if u need any more info u can also use rosin aka gold dust
jaykz1000 is offline
Old 09-26-2007, 03:34 PM
  #3
jaykz1000
Member
MASTER JOURNEYMAN
if u put in sprayer dilute with alchol.. make sure u have some rubber gloves also ... itll get all over ya...
Old 09-27-2007, 06:33 AM
  #4
Tod74
ROOFING TAR.
:lol: jk
Tod74 is offline
Old 09-27-2007, 12:28 PM
  #5
excelerater
Member
MASTER JOURNEYMAN
VHT is not the cure all for track prep and most times
it does more harm than good -
buy some velcro :P
excelerater is offline
Old 09-29-2007, 04:52 PM
  #6
Tod74
:P
How so?
Tod74 is offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
