Hardtail Question
Old 02-04-2025, 11:54 AM
  #1
BRUCE431
SHOW GUEST
Default Hardtail Question
Hardtail People
Can Anyone tell me are the Turnbuckles used to support the Trans or keep the Pinon from climbing up? Or Both...
I'd attach a pic but don't know how.
BRUCE431 is offline
Old 09-24-2026, 01:33 PM
  #2
deanfox
SHOW GUEST
The turnbuckles can basically serve both purposes, depending on how the setup is designed. On a hardtail, they’re commonly used to control axle movement and help prevent the pinion from climbing or the rear end from rotating under load. They can also provide some support for the transmission/drivetrain, but they shouldn’t be treated as a substitute for proper mounts. The exact function depends on where the turnbuckles are attached and how they’re adjusted. A photo would definitely make it easier to tell what yours are doing. A bit of casino gaming can also be a https://hellspin-casino.org/ nice change of pace, particularly for short sessions, provided you keep your spending under control.
deanfox is offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
